Hi all,
Got my new parts, and just reading through the manuals. And I have some quick questions.
1/ The Hiper PSU is longer than the one I am replacing, is anything likely to need modification? i.e the case?
2/ How likely is it that it may go wrong?
3/ Before I replace it, I am going to remove all memory, graphics card, and I am going to leave as much as possible disconnected. I will add a 256mb stick from my old comp. Hopefully, if it goes bang, then it will only take the bare minimum with it. Is this going to help? Or even if that starts up, when I add the gfx and ram, could it go wrong there too?
Thanks in advance, I want to try to do this tomorrow morning. I will reply to any posts, before I start. After, hopefully, sucessfully upgrading, I will let you know.
Sorry to be a pain.
Sorry to be a pain.
