You can sirt that in cmd can’t you? List dusk & create new partition. Google the commands as cant remember
Yes this. I just re- read my reply. Sorry, was rushing as a bus was arrivingYou can. In cmd type:
diskpart
Accept the pop up
Type
list disk
select disk x
list partition
select partition x
delete partition override
That will kill off a partition of any given number. You can then set the disk up in disk manager.
Did you need the partition back with the data that was on it?I didnt mean to partition and now i cant fix it?
