How to format sd card on pc
17 Jun 2012
Bought a used sd card, android says it's damaged. Connected it to the pc and turns out it's full of data(android).
Did chkdsk e: /r
So do I know format it on the pc and if so do I format to fat32 on ntfs or do I just put in back into phone and format from there?
If it has multiple partitions, then you need to use the tool I suggested (or a dedicated partition manager)
