How to get better fps and display?
Monitor: Samsung SyncMaster 305T LCD Monitor
My monitor supports 2560 x 1440 but I can only get a max of 60 fps normally between 30-60 fps in valley with a lower resolution 1920 x 1080 but the higher resolution of 2560 x1440 struggles to hit over 30fps
Quality high
How could i get better results?
2nd question.
If I have the default windows resolution at 2560 x 1440 makes everything look tiny and stretched. so I have it dropped down to 1360 x 1024 (I'm assuming this is a no no) how can I have a higher resolution but not have it stretched
My PC spec below
Quality high
2nd question.
My PC spec below
