Ok I finally got my LSI logic megeraid up and running (i get the ctrl+m) i set up the 2 cheetah in raid 0 64kb strip size. The problem start when i try to install windows xp.
When I go into windows installation it gives me "press F6 to install third aprty SCSI or SATA drivers", so I press f6. after loading sum drivers it gives me an option to install it and I get 4 options of drivers:
MegaRAID SCSI Enterprise 1200
MegaRAID SCSI Enterprise 1500
MegaRAID SCSI Enterprise 1600
MegaRAID SCSI Elite 1650/1700
Now i tried every single one of them and none will work. When i get to the screen where you get to select different drives to install your OS on i get nothing (I only have SCSI array connected when I'm trying to install windows, I tried with WD raptor and it sees it fine, but not the SCSI array). After that my only option is to press f3 to restart th whole system.
Any help would be highly appreciated, cause im completely outta potions at this point sice this is the 1st time I am fiddling with SCSI. I'm pretty sure that my controller is not Dell PERC4 but the original LSI megaraid, so I dont think I have to flash the bios on it.
thanx
thanx
