Hi,
My 5900X tries to maximise performance by significantly increasing vcore to attain ever high clocks. Sometimes that is welcome, but other times not. It generates a lot more heat and subsequently noise from the cooling solution. We know the law of diminishing returns, and for at least some of the time I want to achieve a better compromise.
So mostly I'm running 12 threads, and the clock sits at 4.5GHz with vcore at about 1.3v. I'd like to limit the maximum clock to 4GHz and with that would come less vcore and less heat. How much less vcore that would be I don't know. Ideally I'd like to use Ryzen Master for this so that I can toggle it back to full performance when needed. But I can't see how to do this.
I did try reducing the TDC and that did bring the clock speed down, and the vcore to 1.1v (and 20C less heat) on the 12 threads. Great I thought, but Prime95 immediately failed on a couple of cores so it seems the motherboard/CPU were not intelligent enough to work out the right balance.
Motherboard is MSI B550M Mag Mortar Wifi. If the best way to do this is through the BIOS then that is what I'll do.
Any suggestions for me much appreciated. Happy new year all.
