How to: Mac Mini Media Centre
  • Thread starter Thread starter Deleted member 651465
  • Start date Start date
You realise that Apple have allowed H.264 hardware acceleration - the same nVdidia 9400 acceleration that XBMC on linux uses :D Currently the API is under NDA but I suspect that XBMC and Plex will both have solutions in place..
Great guide EVH!
Quick question though, is there any other way of just adding media without having to go through renaming all my files to conform. How does this work for Series which arent in the online databases as well?
Plex is pretty good at figuring out names of files, it's more to do with having correct directories.
E.g. It will find Lost.S01E01.xvid.avi providing it's in the correct folder and sub folders. In this example, that would be TV Shows > Lost > Season 1.
If you find something that is outside the TV database (thetvdb.org) or the movie database (IMDB) then you can submit the details yourself.
I had to do this for Alan Partridge SE02E03 because it was incorrectly showing as a special episode.
Both sites are free to register :)
Is there anyway to get plex running on a G4 mac mini?
IF not what other options for a media centre do you have ?
As much of an Apple fanboy I've become in recent months I really see no need to do this.
It's just a very over the top way of having an HD Media Player, which basically does the same thing but better (and for only £150).
Still I guess if it's an old mac mini that you would otherwise get rid of it's a good idea.
I've had this in my mind for some time to do away with my W7 htpc (on mediaportal) but the issue I have it recording TV from DVB-T and DVB-S. If this was easy then I'd be over in a flash as its all so much more compact and easier to use. :s
Totally agree, buying a Mac Mini just for this purpose is a waste, but it's perfect for older machines. I use mine as a desktop machine and a media centre (piped around the house to the Plasma etc) so it was a worthy investment.
Have you looked at the Elgato USB sticks? I believe you can customise filenames, so they are output to a folder set or straight to iTunes.
Thinking about it, you could also use Hazel and create some custom scripts to move these recordings to proper folders which Plex could see and import automatically. I haven't done it myself, but it's possible with some work.
Not that I could find. The Plex forums state it's Intel only, leopard only.
XBMC has PPC support, so you could install that and have the "Aeon" skin which I use on Plex :)
http://mirrors.xbmc.org/releases/osx/ppc/xbmc-10.1-ppc.dmg
I'vs just bought a Core 2 Duo 1.66 ghz 1 gig of ram mac mini
seeing as it's the old mac mini i will need this
http://kanexlive.com/products/iAdapt51.html
can you explain how it hooks up ?
usb goes in the back of the mac
audio goes in the back of the mac
mdb goes in the back of the mac
and then i need a hdmi male to male adaptor ?
:confused:
