How to maximise SSD lifespan
20 Jan 2011
City of Doom
was looking at OCZ forums and there wasa debate over P/E cycles with a conclusion that some drives may only last a few years (I have read the sticky here).
If this is true how do you maximise SSD lifespan.
Map My documents to another mechanical drive I would think.
Can you do this with your desktop and internet cache/cookies.
What else could you do, anything in windows to disable/enable
you could run firefox/chrome portable editions for one thing. also log off to allow TRIM to work on it efficiently, regularly.
the idea of remapping your My Docs to a mech HDD is interesting but impossible for me, as I run a number of programs that are hard-coded to access stuff from C:\.... which is a pain.
but the reality is that even if your main OS SSD only lasts a few years, well... that's probably longer than you'd have kept it anyway. i usually change my OS drive every 2-3 years anyway, so not much of an issue for me.
besides, i think the manufacturers will come out with firmware before that happens that allows for much longer lifespan. they're constantly improving reliability and speed with each FW update.
When a SSD comes to the end of its life what will happen, does it gradually degrade or just suddenly stop working.
I got a Samsung MLC SSD and its getting on a bit, should i be worried?
I don't see the point of trying to maximise the life of my SSD's I use a 128GB Samsung in work every day and it gets used the same way as any other drive.
A health test a few weeks back shows it as 98% healthy as I've had it for some time, I read about people turning off the page file and stuff but I really see no point in doing so.
On my 60gb at home I have moved my documents to another drive but thats just because of size limitations
I don't see any harm in trying to maximize the drives life. When it comes to selling it on you'll be able to quote its remaining life and price accordingly.
How much of your own lifespan are you willing to sacrifice in pursuit of this meaningless exercise?
Buy it/Use it/Replace it. Just like any PC component.
Do you underclock your cpu to maximise it's lifespan? Do you stay in bed all day in case you wear your heart out?
If you've got plenty of RAM (6GB+) You can always set your browser temp files to be stored on a RAMDisk (which can be made persistent - On my RAID0 SSD Array it only takes around 3 seconds extra at startup to load a 1.5GB ramdisk image, and around 10 seconds to write it at shutdowns/reboots. This is parallel to the usual startup/shutdown operations so the actual impact is less.
You can do Temp as well but unless you have enough RAM to make a huge RAMdisk you are likely to have space issues.
I did this because a) I had 8GB RAM and most of it goes unused, b) RAMdisk is even faster than an SSD. Minimising my SSD writes is just a beneficial side effect.
I wouldn't bother remapping to a mechanical drive though, the speed tradeoff isn't worth it. By the time your SSD nears the end of it's life (under normal conditions) it'll be practically worthless.
The question was how to maximise its lifespan, it does not need a reply explaining how not too, simples
Oh and staying in bed all day would do a heck of a lot more damage than getting up and being active, so I do get out of bed too maximise my lifespan.
Also, it is worth looking at facts and figures before panicing. People hear that SSDs ware out and go into panic mode. It varies from SSD to SSD, but I was looking at someones math a while back and they worked out that if you write 10gb per day to your SSD then it would wear out in about 5 years (or something hardcore like that for the SSD in question).
To me, that's fine. In even 5 years my SSD will be in the bin as it will be too old and slow and small. In 5 years, SSDs will be all measured in GB/s and not MB/s and they will all be bigger too.
I always thought once a SSD cell wears out it just means you can't write anything new to it. But can continue to read what that cell contains, so could backup contents.
Someone else can confirm or rubbish above statement.
Does a SSD give any read outs to S.M.A.R.T or do the have their own self-monitoring analysing method?
Can use manfacturer supplied tools, if any are available. Here is data using Intel Toolbox (for Intel SSD)
Code:
'Word'	 'Description'	 'Hex Value'
0	 General Configuration	40
	                Bit 15 - ATA Device Identifier	0
	                Bit 14:8 - Retired	0
	                Bit 7:6 - Obsolete	1
	                Bit 5:3 - Retired	0
	                Bit 2 - Response Incomplete	0
	                Bit 1 - Retired	0
	                Bit 0 - Reserved	0
1	 Obsolete	 3FFF
2	 Specific Configuration	 C837
3	 Obsolete	10
4	 Retired	0
5	 Retired	0
6	 Obsolete	 003F
07-Aug	 Reserved	0
9	 Retired	0
Oct-19	 Serial Number	 Mind your own business
20-21	 Reserved	0
22	 Obsolete	0
23-26	 Firmware Version	 2CV102HD
27-46	 Model Number	 INTEL SSDSA2M120G2GC
47	 READ/WRITE MULTIPLE Support	8010
	                Bit 15:8	80
	                Bit 7:0 - Maximum Sectors	10
48	 Trusted Computing Feature Set Options	0
	                Bit 15 - Must be set to 0	0
	                Bit 14 - Must be set to 1	0
	                Bit 13:1 - Reserved	0
	                Bit 0 - Trusted Computing Feature Set Supported	0
49	 Capabilities	 2F00
	                Bit 15:14 - Reserved	0
	                Bit 13 - Standby Timer Option	1
	                Bit 12 - Reserved	0
	                Bit 11 - IORDY Supported	1
	                Bit 10 - IORDY May Be Disabled	1
	                Bit 9 - LBA Supported	1
	                Bit 8 - DMA Supported	1
	                Bit 7:0 - Retired	0
50	 Capabilities	4000
	                Bit 14 - Must be set to 1	1
	                Bit 13:2 - Reserved	0
	                Bit 1 - Obsolete	0
	                Bit 0 - Vendor Specific Minimum Standby timer	0
51-52	 Obsolete	0
53	 Field Validity	7
	                Bit 15:8 - Vendor Recommended Free-Fall Control Sensitivity	0
	                Bit 7:3 - Reserved	0
	                Bit 2 - Word 88 is Valid	1
	                Bit 1 - Words 70:64 are Valid	1
	                Bit 0 - Obsolete	1
54-58	 Obsolete	 3FFF0010003FFC10 00FB
60-61	 Total Number of user addressable sectors	 0DF94BB0
62	 Obsolete	0
63	 Multiword DMA Transfer	7
	                Bit 15:11 - Reserved	0
	                Bit 10 - Multiword DMA Mode 2 Selected	0
	                Bit 9 - Multiword DMA Mode 1 Selected	0
	                Bit 8 - Multiword DMA Mode 0 Selected	0
	                Bit 2 - Multiword DMA Mode 2 Supported	1
	                Bit 1 - Multiword DMA Mode 1 Supported	1
	                Bit 0 - Multiword DMA Mode 0 Supported	1
64	 PIO Transfer Modes Supported	3
	                Bit 15:2 - Reserved	0
	                Bit 1 - PIO Mode 4 Supported	1
	                Bit 0 - PIO Mode 3 Supported	1
65	 Minimum Multiword DMA Transfer Cycle Time Per Word (ns)	78
66	 Device Recommended Multiword DMA Cycle Time (ns)	78
67	 Minimum PIO Transfer Cycle Time Without IORDY Flow Control (ns)	78
68	 Minimum PIO Transfer Cycle Time With IORDY Flow Control (ns)	78
69-74	 Reserved	 4020000000000000 00000000
75	 Maximum Queue Depth - 1	 001F
76	 Serial ATA Capabilities	506
	                Bit 15:13 - Reserved	0
	                Bit 12 - Native Command Queuing Priority Information Support	0
	                Bit 11 - Unload While NCQ Commands Outstanding Support	0
	                Bit 10 - Phy Event Counters Support	1
	                Bit 9 - Receipt of Host-Initiated Interface Power Managament Requests Support	0
	                Bit 8 - Native Command Queuing Support	1
	                Bit 2 - Serial ATA Gen2 Signaling Speed (3.0 Gbps) Support	1
	                Bit 1 - Serial ATA Gen1 Signaling Speed (1.5 Gbps) Support	1
	                Bit 0	0
77	 Reserved for Serial ATA	0
78	 Serial ATA Features Supported	48
	                Bit 15:7 - Reserved	0
	                Bit 6 - Software Settings Preservation Supported	1
	                Bit 5 - Reserved	0
	                Bit 4 - In-Order Data Delivery Supported	0
	                Bit 3 - Device Initiating Interface Power Management (DIPM) Supported	1
	                Bit 2 - DMA Setup Auto-Activate Optimization Supported	0
	                Bit 1 - Non-Zero Buffer Offsets in DMA Setup FIS Supported	0
	                Bit 0 - Must be set to 0	0
79	 Serial ATA Features Enabled	40
	                Bit 6 - SSP Enabled	1
	                Bit 5 - Reserved	0
	                Bit 4 - In-Order Data Delivery Enabled	0
	                Bit 3 - Device Initiating Interface Power Management (DIPM) Enabled	0
	                Bit 2 - DMA Setup FIS Auto-Activate Optimization Enabled	0
	                Bit 1 - Non-Zero Buffer Offsets in DMA Setup FIS Enabled	0
80	 Major Version Number	 00FC
	                Bit 15 - Reserved	0
	                Bit 14 - ATA14 Support	0
	                Bit 13 - ATA13 Support	0
	                Bit 12 - ATA12 Support	0
	                Bit 11 - ATA11 Support	0
	                Bit 10 - ATA10 Support	0
	                Bit 9 - ATA9 Support	0
	                Bit 8 - ATA8-ACS Support	0
	                Bit 7 - ATA/ATAPI-7 Support	1
	                Bit 6 - ATA/ATAPI-6 Support	1
	                Bit 5 - ATA/ATAPI-5 Support	1
	                Bit 4 - ATA/ATAPI-4 Support	1
	                Bit 3 - Obsolete	1
	                Bit 2 - Obsolete	1
	                Bit 1 - Obsolete	0
	                Bit 0 - Reserved	0
81	 Minor Version Number	 001A
82	 Features/Command Sets Supported	 746B
	                Bit 15 - Obsolete	0
	                Bit 14 - NOP Command Supported	1
	                Bit 13 - READ BUFFER Command Supported	1
	                Bit 12 - WRITE BUFFER Command Supported	1
	                Bit 11 - Obsolete	0
	                Bit 10 - HPA Feature Set Supported	1
	                Bit 9 - DEVICE RESET Command Supported	0
	                Bit 8 - SERVICE Interrupt Supported	0
	                Bit 7 - Release Interrupt Supported	0
	                Bit 6 - Read Look-Ahead Supported	1
	                Bit 5 - Write Cache Supported	1
	                Bit 4 - Must be set to 0	0
	                Bit 3 - Power Management Feature Set Supported	1
	                Bit 2 - Obsolete	0
	                Bit 1 - Security Mode Feature Set Supported	1
	                Bit 0 - SMART Feature Set Supported	1
83	 Features/Command Sets Supported	 7D01
	                Bit 13 - FLUSH CACHE EXT Command Supported	1
	                Bit 12 - Mandatory FLUSH CACHE Command Supported	1
	                Bit 11 - DCO Feature Set Supported	1
	                Bit 10 - 48-Bit Address Feature Set Supported	1
	                Bit 9 - AAM Feature Set Supported	0
	                Bit 8 - HPA Security Extensions Supported	1
	                Bit 7 - Reserved for Address Offset Reserved Area Boot Method	0
	                Bit 6 - SET FEATURES Subcommand Required to Spinup After Power-Up Supported	0
	                Bit 5 - PUIS Feature Set Supported	0
	                Bit 4 - Obsolete	0
	                Bit 3 - APM Feature Set Supported	0
	                Bit 2 - CFA Feature Set Supported	0
	                Bit 1 - TCQ Feature Set Supported	0
	                Bit 0 - DOWNLOAD MICROCODE Command is Supported	1
84	 Features/Command Sets Supported	6163
	                Bit 13 - IDLE IMMEDIATE With UNLOAD FEATURE Supported	1
	                Bit 12 - Reserved for Technical Report	0
	                Bit 11 - Reserved for Technical Report	0
	                Bit 10:9 - Obsolete	0
	                Bit 8 - 64-Bit World Wide Name Supported	1
	                Bit 7 - WRITE DMA QUEUED FUA EXT Command Supported	0
	                Bit 6 - WRITE DMA FUA EXT Command Supported	1
	                Bit 5 - GPL Feature Set Supported	1
	                Bit 4 - Streaming Feature Set Supported	0
	                Bit 3 - Media Card Pass Through Command Feature Set Supported	0
	                Bit 2 - Media Serial Number Supported	0
	                Bit 1 - SMART Self-Test Supported	1
	                Bit 0 - SMART Error Logging Supported	1
85	 Features/Command Sets Enabled	7469
	                Bit 15 - Obsolete	0
	                Bit 14 - NOP Command Enabled	1
	                Bit 13 - READ BUFFER Command Enabled	1
	                Bit 12 - WRITE BUFFER Command Enabled	1
	                Bit 11 - Obsolete	0
	                Bit 10 - HPA Feature Set Enabled	1
	                Bit 9 - DEVICE RESET Command Enabled	0
	                Bit 8 - SERVICE Interrupt Enabled	0
	                Bit 7 - Release Interrupt Enabled	0
	                Bit 6 - Look-Ahead Enabled	1
	                Bit 5 - Write Cache Enabled	1
	                Bit 3 - Power Management Feature Set Enabled	1
	                Bit 2 - Obsolete	0
	                Bit 1 - Security Mode Feature Set Enabled	0
	                Bit 0 - SMART Feature Set Enabled	1
86	 Features/Command Sets Enabled	 BC01
	                Bit 15 - Words 119-120 Are Valid	1
	                Bit 14 - Reserved	0
	                Bit 13 - FLUSH CACHE EXT Command Enabled	1
	                Bit 12 - Mandatory FLUSH CACHE Command Enabled	1
	                Bit 11 - DCO Enabled	1
	                Bit 10 - 48-Bit Address Feature Set Enabled	1
	                Bit 9 - AAM Feature Set Enabled	0
	                Bit 8 - HPA Security Extensions Enabled	0
	                Bit 6 - SET FEATURES Subcommand Required to Spinup After Power-Up	0
	                Bit 5 - Power-Up In Standby Feature Set Enabled	0
	                Bit 4 - Obsolete	0
	                Bit 3 - APM Feature Set Enabled	0
	                Bit 2 - CFA Feature Set Enabled	0
	                Bit 1 - TCQ Feature Set Enabled	0
	                Bit 0 - DOWNLOAD MICROCODE Command Enabled	1
87	 Features/Command Sets Enabled	6163
	                Bit 13 - IDLE IMMEDIATE With UNLOAD FEATURE Enabled	1
	                Bit 8 - 64-Bit World Wide Name Enabled	1
	                Bit 7 - WRITE DMA QUEUED FUA EXT Command Enabled	0
	                Bit 6 - WRITE DMA FUA EXT Command Enabled	1
	                Bit 5 - GPL Feature Set Enabled	1
	                Bit 4 - Streaming Feature Set Enabled	0
	                Bit 3 - Media Card Pass Through Command Feature Set Enabled	0
	                Bit 2 - Media Serial Number Enabled	0
	                Bit 1 - SMART Self-Test Enabled	1
	                Bit 0 - SMART Error Logging Enabled	1
88	 Ultra DMA Modes	 407F
	                Bit 15 - Reserved	0
	                Bit 14 - Ultra DMA Mode 6 Selected	1
	                Bit 13 - Ultra DMA Mode 5 Selected	0
	                Bit 12 - Ultra DMA Mode 4 Selected	0
	                Bit 11 - Ultra DMA Mode 3 Selected	0
	                Bit 10 - Ultra DMA Mode 2 Selected	0
	                Bit 9 - Ultra DMA Mode 1 Selected	0
	                Bit 8 - Ultra DMA Mode 0 Selected	0
	                Bit 7 - Reserved	0
	                Bit 6 - Ultra DMA Mode 6 and Below Supported	1
	                Bit 5 - Ultra DMA Mode 5 and Below Supported	1
	                Bit 4 - Ultra DMA Mode 4 and Below Supported	1
	                Bit 3 - Ultra DMA Mode 3 and Below Supported	1
	                Bit 2 - Ultra DMA Mode 2 and Below Supported	1
	                Bit 1 - Ultra DMA Mode 1 and Below Supported	1
	                Bit 0 - Ultra DMA Mode 0 and Below Supported	1
89	 SECURITY ERASE UNIT Time	1
90	 ENHANCED SECURITY ERASE UNIT Time	1
91	 Advanced Power Management Level	0
	                Bit 15:8 - Reserved	0
	                Bit 7:0 - Level	0
92	 Master Password Revision Code	 FFFE
93	 Hardware Reset Result	0
94	 Current Automatic Acoustic Management Value	0
	                Bit 15:8 - Vendor's Recommended Value	0
	                Bit 7:0 - Current Value	0
95	 Stream Minimum Request Size	0
96	 Streaming Transfer Time - DMA	0
97	 Streaming Access Latency - DMA and PIO	0
98-99	 Streaming Performance Granularity	0
100-103	 Maximum User 48-Bit LBA	 000000000DF94BB0
104	 Streaming Transfer Time - PIO	0
105	 Maximum 512-byte blocks of LBA Range Entries per DATA SET MANAGEMENT command	8
106	 Physical / Logical Sector Size	4000
	                Bit 13 - Device has Multiple Logical Sectors Per Physical Sector	0
	                Bit 12 - Logical Sector Size Larger than 256 Words	0
	                Bit 11:4 - Reserved	0
	                Bit 3:0 - 2^Value Sectors Per Physical Sector	0
107	 Inter-Seek Delay for ISO7779 Standard Acoustic Testing	0
108-111	 World Wide Name	 5001517959465F06
112-116	 Reserved	 0000000000000000 0000
117-118	 Logical Sector Size	0
119	 Features/Command Sets Supported	 401C
	                Bit 13:6 - Reserved	0
	                Bit 5 - Free-Fall Control Feature Supported	0
	                Bit 4 - DOWNLOAD MICROCODE Command With Mode 3 Supported	1
	                Bit 3 - READ/WRITE LOG DMA EXT Optional GPL Commands Supported	1
	                Bit 2 - WRITE UNCORRECTABLE EXT Command Supported	1
	                Bit 1 - Write-Read-Verify Feature Set Supported	0
	                Bit 0 - Reserved for DDT	0
120	 Features/Command Sets Enabled	 401C
	                Bit 5 - Free-Fall Control Feature Enabled	0
	                Bit 4 - DOWNLOAD MICROCODE Command With Mode 3 Enabled	1
	                Bit 3 - READ/WRITE LOG DMA EXT Optional GPL Commands Enabled	1
	                Bit 2 - WRITE UNCORRECTABLE EXT Command Enabled	1
	                Bit 1 - Write-Read-Verify Feature Set Enabled	0
121-126	 Reserved For Expanded Supported and Enabled Settings	 0000000000000000 00000000
127	 Obsolete	0
128	 Security Status	21
	                Bit 15:9 - Reserved	0
	                Bit 8 - Master Password Capability	0
	                Bit 7:6 - Reserved	0
	                Bit 5 - Enhanced Security Erase Supported	1
	                Bit 4 - Security Count Expired	0
	                Bit 3 - Security Frozen	0
	                Bit 2 - Security Enabled	0
	                Bit 1 - Security Locked	0
	                Bit 0 - Security Supported	1
129-159	 Vendor Specific	 0000000000000000 0000000000000021 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 000000000000
160	 CFA Power Mode	0
161-167	 Reserved for CFA	 0000000000000000 000000000000
168	 Device Nominal Form Factor	0
	                Bit 15:4 - Reserved	0
	                Bit 3:0 - Form Factor	0
169	 Data Set Management Support	1
	                Bit 15:1 - Reserved	0
	                Bit 0 - Data Set Management Supported	1
170-175	 Reserved	 0000000000000000 00000000
176-205	 Current Media Serial Number	 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 00000000
206	 SCT Command Transport	0
	                Bit 15:12 - Vendor Specific	0
	                Bit 11:6 - Reserved	0
	                Bit 5 - SCT Data Tables Supported	0
	                Bit 4 - SCT Features Control Supported	0
	                Bit 3 - SCT Error Recovery Control Supported	0
	                Bit 2 - SCT Write Same Supported	0
	                Bit 1 - SCT Long Sector Access Supported	0
	                Bit 0 - SCT Command Transport Supported	0
207-208	 Reserved	0
209	 Alignment of Logical Blocks Within a Physical Block	0
210-211	 Write-Read-Verify Sector Count Mode 3	0
212-213	 Write-Read-Verify Sector Count Mode 2	0
214	 NV Cache Capabilities	0
215-216	 NV Cache Size In Logical Blocks	0
217	 Nominal Media Rotation Rate	1
218	 Reserved	0
219	 NV Cache Options	0
220	 Write-Read-Verify Mode	0
	                Bit 7:0 - Write-Read-Verify Feature Set Current Mode	0
221	 Reserved	0
222	 Transport Major Version Number	 101F
	                Bit 15:12 - Transport Type	1
	                Bit 11:5 - Reserved	0
	                Bit 4 - SATA Rev 2.6 Supported	1
	                Bit 3 - SATA Rev 2.5 Supported	1
	                Bit 2 - SATA II: Extensions Supported	1
	                Bit 1 - SATA 1.0a Supported	1
	                Bit 0 - ATA8-AST Supported	1
223	 Transport Minor Version Number	0
224-233	 Reserved	 0000000000000000 0000000000000000 00000000
234	 Minimum Number Of Blocks Per DOWNLOAD MICROCODE Mode 3	1
235	 Maximum Number Of Blocks Per DOWNLOAD MICROCODE Mode 3	 01F0
236-254	 Reserved	 0000000000000000 0000000000000000 0000000000000000 0000000000000000 000000000000
255	 Integrity Word	 FAA5
'ID'	 'Description'	 'Raw'	 'Normalized'	 'Threshold'	 'Recommended Action'
3	 Spin Up Time	0	100	0	 Ready for use.
4	 Start/Stop Count	0	100	0	 Ready for use.
5	 Re-allocated Sector Count	0	100	0	 Ready for use.
9	 Power-On Hours Count	305	100	0	 Ready for use.
0C	 Power Cycle Count	98	100	0	 Ready for use.
C0	 Unsafe Shutdown Count	3	100	0	 Ready for use.
E1	 Host Writes	 395.69 GB	200	0	 Ready for use.
E8	 Available Reserved Space	0	100	10	 Ready for use.
E9	 Media Wearout Indicator	0	99	0	 Ready for use.
B8	 End to End Error Detection Count	0	100	99	 Ready for use.
SSD's may have a longer useable/desireable life than mechnical HD's because the performance is mega, you might just use it for certain games/apps in future
