How to network Win 7 with XP?
14 Oct 2007
wubalubadubdub
Is it possible to network a windows 7 pc with an XP pc, with internet sharing (gateway with Win 7 being the primary) without breaking all windows 7 security settings like some pages suggest after a google search?
my setup is a direct cable modem to pc via ethernet to onboard LAN, there is a PCI network card with a crossover cable that connects to the onboard LAN on the XP machine
Finally figured out how to do this :D
very simple once i found it and i can keep all the 128 bit/password protection settings on windows 7 and the connection is shared across the network, the only down side is that the shared folders only work on a 1 way system as in I can only transfer files from Win7 to XP (unless I 'grab' the files from the XP shared folder)
