Hi all. this will my first post, and with a question that will be probably a bit long, and with "poor" english, but I´ll do my best to make myself be understood.
I have a Msi r7850 twin frozr 2gds, it´s normal clock speed is 900Mhz with 1200Mhz X 4 = 4800Mhz memory speed. My CPU is an i5-3350, motherboard asus p8h77-m, power unit corsair 550w 6Gigs or RAM. I have it overclocked with asus tweak utility to 1200Mhz clock speed and 5800Mhz memory speed. Its stable like it is. I´ve been reading this thread, and comparing my benchmarks with heaven 3.0 and P 3DMark11, and my scores don´t even come close to the results I´ve seen here with 7850´s.
In heaven 3.0 with 1980x1080p, Tesselation normal, Shaders high, Anisotropy 4x, Anti-aliasing 4x my "best" score was 608
In P test with 3DMark11 the score was 6541
So, nothing compared to the scores I´ve seen in here with the same benchmarks.
In Crisis 2 with full textures and everything on ultra I get no less than 47fps and hit 60fps sometimes, wich I think it´s not bad at all.
My question is, what can be the cause to so poor benchmarking with heaven and 3dmark11? I´ve downloaded all the latest drivers. (can it be an opencl.dll related problem?, I´ve tried every single solution i found on the web and
can´t make it go away. (Finaaly i solved the opencl.dll missing problem, downloaded opencl.dll version 1.2 and copyed it to system32 folder...problem fixed...but benchmark results did´t improve, so it wasn´t opencl related problem
