Hi Guys,
Think I've got a bit of a donkey for overclocking as can only get 1040 at stock volts!
1050 @ 1.14V but at 1.2V I can only get to 1080
Max temps of about 60c
I upped the power offset to 20%, ran driver sweep before installing the latest drivers (12.8) along with CAP1.3 and haven't installed CCC or Afterburner.
I keep getting d3d11appwindow swap_window() device removed if I push it over the above settings in GPU Tweak along with Heaven freezing or black screens.
Is there anything else I can do or just accept that's the way it is sometimes?!
Any suggestions gratefully received....
EDIT - I've left the memory at stock if that makes any difference. ASIC 76.8
try voltage at 1.172v and core at 1.172mhz and memory at 5500mhz (using asus gpu tweak)
