how to really cook a cpu?
Permabanned
6 Feb 2010
Barnsley
Best way to make a sandy bridge CPU hot?
i am using aida64.
i have a e3 1270 4c8t, when the test i see as max of 69c...
the CPU is been cooled with a celeron 50w stock heatsink.
i dont think aida64 is doing it job, i am about to fit a new cooler and i want to test the max temps under silly load so i can set a fan profile
Intel Burn Test (IBT)
Came here to say this.
Same IBT MAXIMUM nothing puts more heat. Max I'w pumped out of ryzen on it was 202 wats :D thats like 210% TDP haha
this is the same program at LinX right? when i use LinX it shows it working and running tested but doesnt load up the cores and there in no change in temp.
it completes the test and tells me my system is stable but it doesn't actually run
Prime95, with the stock cooler hits 85c lol... thats a big set up from the 69 aida64 was giving me.
with new cooler Prime95 sits at 67c, ig games it hovers around 50c so i am happy.
Intel Burn test AND furmark .. but take out your discrete GPU . The only real problem with this is that furmark steals somes cycles from the cpu stressor. whoops just seen no inbuilt gfx ,
