How to remove excess text?
Permabanned
23 Jun 2009
Odd request, but I've got a document which has every line repeated underneath it.
eg:
xxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxx
yyyyyyyyyyyyyyy
yyyyyyyyyyyyyyy
zzzzzzzzzzzzzzzzz
zzzzzzzzzzzzzzzzz
Is there anyway to remove the repeated stuff without doing it manually as there is around 30 pages to get through :/
Thanks
Word or text editor use find/replace, enter pattern for find, leave replace as space and replace all, done.
Write a program in Java (or another programming language of choice) to parse the file character by character removing them? :D
Textpad marco to delete every second line? (If you have Textpad) Word macro to delete every second line?
Get a macro keyboard, record macro of holding shift, pressing down and then pressing delete.
Then run it on repeat :p
you can do some excel formula using an IF eg if the line below = the current line that insert DELETETHIS otherwise insert the line value.
then do a find and replace on the DELETETHIS once its back in the word doc
just copying to a new location and removing duplicates would be enough.
a macro in word'll have it done in a jiffy.
just record "down, home, shift-end, delete" and then run the macro until it's finished.
but page breaks, paragraphs and other things might mean that you delete the wrong stuff ;)
