- 15 Mar 2004
- Oxford
Hello Thar,
I've got an arcylic Fish Tank/Vivarium from a while ago.
The previous owner decided to put gaffa tape around the top and bottom of the tank to create a border. Now its been on there a long time as it won't peel off very easy !
Gettting the actual balck tape of is easy but removing the glue left behind afterwards is impossible to me.
So any ideas on how i can remove it ?
I've boiled the kettle and poured that over it and scrubbed to no avail so please help me
Thanks
Thanks
Anything solvent based should do it, just be careful not to use anything too nasty on it if it's acrylic.
