- 15 Feb 2010
Does anyone know how to turn this feature off so my drives as always blue in windows 7, or at least make the percentage before it goes red smaller?
)Guys is it really wise to buy a new hard drive or constantly move data around just so that i don't have to have a red icon on my hard drive? Don't you think it is a bit much? Don't you think they should have an option to disable it or increase it; this is 2010 after all
DogsBody thank you very much for the link, unfortunately though this only works for removing the "you are running out of space" notification when really low on space. Anybody else got ideas about removing the red? Thanks for the help
You think it is any more pointless than all these pointless comments some people are making?
You think it is any more pointless than have the red warning when i have "just" 50GB+ left, because that is such a dangerously small amount isn't it?
Its 2010 so we should have the option to tweak our user interface; no more comments about how nit-picky I'm being please! Just comment if you have a solution thanks
Snooble said:You have an OCD.
