- 13 Apr 2013
- La France
Use a parallel spline extractor. Those tapered ones can actually deform the screw/bolt you're trying to remove and make it jam on the surround part.
Drill it out and forget it ever existed, the wheel bolts hold the disc in place anyway,
right... I've done some reading and it does look very much like 'the wrong kind' of extractor is going to shatter into billion pieces and leave me stuffed.
Can someone link me up to one that is going to do the job please?
Use an extractor, out in 2 mins flat no problem.
The only point is to hold the disc to the hub when you refit/remove the wheel to stop it moving. Once the disc has been fitted for a few days it will stick anyway.
I can't honestly figure out why you're so desperate to get this out? Are people remembering that it's a brake disc screw here..what's the point??
Just drill about 6-8mm drill to take the screw head off and the disc will come off, the stub is then usually loose, but if not, use molegrips to unscrew as already said.
To be more clear - I can't figure out why he is so bothered about getting it out without just drilling the head off it and accepting the rest may or may not come out.
Honestly forget extractors and all that crap, just get a decent drill bit and drill the head out. I don't know if you have ever drilled a screw out before, but if you use a reasonably large bit then the head of the screw just drops away ams leaves you with a little stub. You can either continue to try and drill out the stub, or just leave it as it is.
