How to remove the jumper on seagate 500gig?
Unless it's easy to get to don't bother with it, you won't notice a difference.
All that removing the jumper does is allow the drive to run in SATA2/300Mb/s mode, it's not actually capable of sustaining more than about 80Mb/s so all that improves is the burst rate from the cache. The real world effect of this is just about negligible.
so there is no point of removing it?
I see where's the jumper but i dont know how i must remove it - do i have to pull that piece of thing that is on 2 pins?
i have 4 pins there - 2 of them are blocked becouse of it,do i need to just ,, you know ... pull it?
I think forgetting to remove one from my 4x 500gb RAID5 array is causing my hd-tach benchmarks to fluctuate horrendously :s
whether they actually make any difference or not is debatable; but make sure they're all the same; I've got to power the box down again :(
rpstewart said:
While your at it turn the NCQ off too, it messes up RAID performance something chronic. I got about 20% better performance on my RAID5 array when I disabled it on all the drives.
yeah, ncq is a nightmare sometimes, on nvidia arrays it makes them crawl!
