I've had a screen protector on my phone for a while which comes with a plastic strip that goes over the button at the bottom to make it easier to press the button with the screen protector around it.
The plastic strip has come off and I tried to re-attach it with some glue but it didn't work and now the button on the phone is sticky and is a lot harder to press.
What would be the best way to remove it without damaging the phone?
I was thinking of using some isopropyl alcohol and q tips to remove it. I have a kit for removing thermal paste from cpus that might work.
It's a samsung s5 mini. The glue contains cyanoacrylate.
