- 25 Mar 2004
- Fareham
Hi,
I have a new build home, and for some reason they made two of my ceiling light fittings into these strange ones that don't take normal bulbs (attempting to save energy maybe!). Even though you can get LED standard bulbs now...
I'd like to get them swapped for normal screw bulb or bayonet fixings if possible, however how easy is this to do? I'm certainly no electrician.
Fitting I want to replace:
The type of bulb it presently takes:
I'd guess I'll probably be best off getting an electrician in to do the job?
Cheers!
Cheers!
