http://www.ebay.co.uk/itm/Unified-U...013?pt=LH_DefaultDomain_3&hash=item2c54a47cc5
Just to double check, this bit is OK, says something about lead?
Nope, you need a first (or starting), not a second.
There are three taps used
Starting (actually called a taper)
Second
Finishing or bottom
As long as you have the clearance / depth to get the first/starting tap all the way in then don'bother with the others, the screw will fit fine.
So what is it lol
One person says I need a first other saying a second is great!!
To do the job correctly, you need all three taps...
They all do different jobs (I know, it's a tap what more can it do...) Starter to start the proccess easier, Second to get the threads in and a finisher to finish off the tap, so the screw can go in by finger, most don't use a finishing tap, that's why you need a ratchet/screwdriver/spanner to even get the bolt/screw/whatever in...
Ive just been forcing screws in with a screw driver just fine, so cheap and cheerful second tap it is. Surely will be better than my previous efforts.
As 6/32 isn't metric and they are rather harder to find, if you can find a first (taper tap) go for it. If not you shouldn't run into any trouble with a second.
Well I'm glad we got there in the end.![]()
