- 16 Oct 2005
Hi,
Ive built a couple of PCs before and never had any problems. Except for this one.
Its a mishmash of components, but it was working fine a few months ago. I come back to it now, and it won't post... I get the OK lights on the motherboard, continuous fan on, but no post at all, and no beeps. I've tried running it with just the CPU and motherboard and vid card on apiece of cardboard, same symptoms. I've tried swapping the PSU, same symptoms. I've tried swapping the vid card, same symptoms. If it helps, I also noticed that pressing the caps lock key on the keyboard doesn't move the LED.
As the problem occurs with just the CPU, mobo, GPU, and PSU connected, and I know it isnt the GPU or PSU, then it must be the CPU or motherboard - but how can i tell which without components to swap?
the cpu is a barton 2500, motherboard abit nf7.
Thanks for reading this
