How to test new build?
26 Jun 2009
London
Right I've just put together my new I7 pc and I'm pretty new to windows.
I've installed win7 ok but want to test all the components and make sure its all running properly. Can you guys let me know what I can use to double check everything.
Thanks
Just put my specs in my signature.
Gigabyte UD5 // Intel I7 // 6GB DDR3 Corsair ram // Fractal R2 case // Megahalems // XFX ATI 5870
Well you can download 3mark which will give you a score to compare against similar systems.
Prime95 will test your CPU, and give you a result which you can compare.
Can use memtest to check your ram.
And Orthos to really stress your CPU to see if its stable.
