How to tighten long input jacks?
Suspended
3 Mar 2003
London ;()!
Hi guys
Kinda urgent this one, my input jack on the guitar is going loose. Its the long, cylindrical type jack... the sort that covers the entire plug unlike the sort you get on most guitars where you can just squeeze the contacts together. My question to you is this - how do I tighten the contacts?
This.
If it's the type I'm thinking of, you can unscrew the bezel, pull it out, check/replace the soldered connections and crimp if necessary.
*n
cleanbluesky said:
It must undo, otherwise it could not have had wires soldered onto it
Look at the picture. The wires solder onto the big bit and the little pin sticking out the end. What I'm saying is that the grip on the cable inside the barrel is poor and needs tightening.
You mean the grip that the female socket (in the guitar) has on the male socket (on the lead) is poor?
Like I said - open it up and crimp it.
All the ones I've used have unscrewed.
*n
Bad news - you will have to replace it.
You can't get into them and your only chance is a powerful magnifying glass, torch and very thin screwdriver to see if you can prise the contact out.
They are readily available at an Electronics Hight Street store.
While you're at it buy the normal type and see if that will fit instead.
Thought so.
I buy these things every 6 months or so and its driving me crazy. The body is too thick to put a normal jack in - thinking of having a shop drill it out :eek: its for the best...
Chronos-X said:
Thought so.
Every six months.. what in God's name do you do to your guitar :eek:
Plug it in? It doesn't cut out every 6 months, but it gets to the stage where the slightest of pressure on the jack causes it to cut out. So when the cable hits your leg... it goes
