How to use Multiple Case Fans
Thanks for the quick response - I will actually have 4 fans if I count the Corsair Fan on the radiator for my Corsair H60. So that makes it
1 Corsair fan
2 Bitfenix fans with the Bitfenix Prodigy
1 Noctua fan that I ordered extra.
Im guessing there is no 3 pin x 4 wire?
Assuming you have the Prodigy, why don't you get a fan controller like the BitFenix Recon and use an external ODD?
Not much use for one these days.
I'm not using a optical disk drive. How many fans can I plug into the recon? I removed the optical drive bay an kept an extra fan over there but I guess I can remove that fan and put 2 on top of the case instead.
