How to wipe my hard drive?
13 Jan 2010
Ok, I just bought Windows 7 and I'm currently running VISTA, I don't want to upgrade but rather have a clean install, the thing is...I know nothing of wiping my HD.
I don't know how to burn Iso's or anything, are there any programs out there or anyone who can give me some help/point my in the right direction?
I've currently downloaded HDDErase and Using that currently. Thanks
Just pop the Windows 7 disk in and after loading some files it will ask you where you want to install it to. At this point you can format your drive and have a clean fresh install.
You're probabaly best just doing a total full format.
Put the Windows 7 disk in your DVD drive, restart your computer, go into your bios (usually delete button) and look for something called boot priority and set it to CD/DVD Drive.
Save bios settings and exit, your computer will restart again and you should see a piece of text that says 'Press and key to boot from CD/DVD...' when you've done that, you'll come to the setup of a new operating system.
It will give you an option to Format which ever hard drive you want, there will be two options, Quick Format, and Format, just pick quick format on your c: drive.
If you're looking to wipe your hard drive for security reasons, using the Secure Erase command via the HDDErase utility is your best bet. However, if there isn't any data which you consider important on the disk, and just wish too do a clean installation, a quick format is fine which the Windows 7 setup program will give you the option to do before you go ahead and install Windows 7.
Is there no way to go from 32bit to 64bit without wiping my HD? If I insert the 64bit disk I simply get error messages
What sort of error messages are you receiving?
You are booting directly from the dick in BIOS, yes?
You're not loading windows on the old PC and sticking in a 64-bit disk and hoping to achieve a fresh install from there?
That might be the source of your error messages.
What error messages?
If I am installing on SSD does the reformat equate "aligning" or does it align automatically?
:confused:
