- 7 Mar 2005
- LU7
I've got a brick arrangement in my basement that mirrors where the fireplaces are on the ground and first floor. There is no fireplace in my room nor a flue. To give me more options to run network and HDMI cables around the room I've been thinking about the possiblity of making a 50mm circular hole through both the sides of the brick arrangement. Each side of the brick arrangement is about 10 inches thick. I currently store my DVD collection within the arrangement. There is 33 inches between each side of the brick arrangement hence the need to make 2 holes of about 10 inches deep. My plan is to make the hole as close to the floor and the back of the brickwork as possible.
Not being a DIY-er in any way is such a thing possible? I guess I'd need a decent drill and an accessory that would go through brick and give me a 50mm circular hole? Can anyone recommend such a drill and accessory to do this? No ideas on budget for this yet. Would it be worth just hiring a drill and the necessory accessories rather than buying a drill for what is effectively a one-off job?
I realise I may not have given all the details needed to help answer my query so please feel free to ask if you need more information to come up with a solution.
