- 7 Mar 2005
- LU7
50mm is just a bit wider than a mains plug. I would want to be able to extend mains as well by using an extension lead. I could remove the plug, run the cable through and re-attach the plug.Why does it need to be 50mm?
If you're just wanting to run cables then a couple of 25-30mm holes should be adequate and much easier to achieve using more basic tools.
After a few cables have gone through I think 20mm would be too small to run another cable through.A 20mm hole is sufficient for a terminated hdmi cable (i ran hdmi everywhere here) and achievable with a regular sds drill
The hole isn't through a wall. It's through a brick arrangement jutting out from a wall. The hole would run parallel to the back wall. Hopefully this image explains it a bit better.Is 50mm going to be wide enough? I'm guessing that you're going to need to put a pipe in there to connect the two holes, else cables could get lost in the space between the walls.
https://dl.dropboxusercontent.com/u/6462594/drilling.jpg
