Hxc said:Unless I'm missing something (only doing GCSE maths currently), e stands for any number, correct?
say e = 2
2^pi = 8.82497783
pi^2 = 9.8696044
Which means that either your statement is incorrect, or that I do not know what e is![]()
It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt.
DaveF said:Consider f(x) = ln(x) / x. f'(x) = (1 - ln x) / x^2. So f'(x) < 0 for x > e, and so f(e) > f(pi).
So ln(e)/e > ln(pi) / pi. So pi ln(e) > e ln pi. Apply exp to both sides to get e^pi > pi ^ e.
sid said:I have a feeling there may be something more elegant.
IF this was a interview question, then they can't expect ppl to do that on the spot, needs a pen and paper.
The interviews aren't "sit on a chair in the middle of a room and be interrogated," you usually sit down at a table with one or two people and go through some questions.Calder said:I had interviews for Engineering at both Cambridge and Oxford and was asked similar problem solving questions, you're allowed a pen and paper.The interviews aren't "sit on a chair in the middle of a room and be interrogated," you usually sit down at a table with one or two people and go through some questions.
Sleepy said:some faggot comment
Not that tough (though of course they'll give you hints as necessary).sid said:Back to the problem, I think thats a toughie without perhaps a hint.
Psyk said:Sounds quite tricky, especially since it seems kind of obvious. But it being obvious doesn't count as proof.
DaveF said:Not that tough (though of course they'll give you hints as necessary).
As you say, an obvous step is to take logs, so you're comparing
pi with e ln pi. So you want to compare e with pi / ln pi.
At which point looking at f(x) = ln(x)/x isn't that big a leap.
Then f(x) has a maximum at x = e, where f(x) = 1/e. So 1/e < ln pi / pi, so e > pi / ln pi.
The answer I gave is with "benefit of hindsight" to make it shorter, but the above shows how you might find it yourself.
Well when you raise to a power your answer grows exponentially. Since pi is greater than e, but not by a huge amount, you'd expect e^pi to bigger.PinkPig said:How is it obvious? (Short of spending quite a while working out upper and lower bounds in your head on what each answer can be)
So I guess it's also obvious that 3^2 < 2^3, right?sid said:BTW Its obvious because Exponentials pwn Polynomials lol
