hp 6930p laptop problems?
25 Nov 2011
Cumbria, United Kingdom
hey all, just bought a refurb laptop off eb*y, source4bits was the seller. anyways, it was grade A+.
Anyways, the problem is,
when you use the touchpad left button to minimise a window, the window develops severe graphical glitches that make the text illegible. It also does the same with a usb mouse now. i have a 90 day RTB warranty. It causes severe glitches across the entire page. it was running windows vista, had a fresh install of windows 7. it happens less with the mouse. what do you think the issue is?
thanks
ste
has all latest drivers. installed the hp protect tools and its saying there is a .dll file missing. it is not a virus, its not been connected to the net, im wondering if it is a hardware fault.
HP laptops are notorious for the IGP failing due to poor cooling!
It could well be that the guy did a bodge job and reflowed the solder on the IGP (hence the refurb) to get it working to then sell it on. Sounds like it's on it's way out, best return it now i think.
i dont think its been taken apart, apart from the ram cover bay was bowed, but i only paid 215 for it, offered him 215 as he wanted 250 which he accepted. its weird though because if you click off of a box, click back on it, the distorted text will dissapear then re appear when you close&re open it again. its really weird. what will those tests tell me by the way? what difference does the temp of the processor make?
How can it be refurbished but not have been opened? :/
The graphics "glitching" is going to be either the graphics drivers (which you say it's not). Try booting into safemode and see if it does it too (will help eliminate the driver as the issue).
Or it's the memory or the IGP itself. If you google HP laptop GPU error you'll see how common it is for them to fail. I have "reflowed" 10 myself in the last 6 months or so!!
I suspect it will fail and you get the tell tale long and then 2 short beeps :(
If you dont have it already. Download ultimateboodcd or a similar free bootdisk. They are packed with useful tools for testing RAM, CPU, HDDs and temps etc etc.
my dads a tecky, so will use the hirens disk, will try booting safe mode, could it be because its windows 7 64 bit and it has the fingerprint scanner? ive read that hp havent provided suitable drivers for the fingerprint reader for windows 7 64 bit.
by the way, turned off windows virtualization, seems to have fixed it temporarily, as not having the issue at the moment, been fine for 30mins or so. if it persists ill try booting in safe mode :) I just dont get why it only does it to text within a folder (e.g. a folder name will be scrambled letters and the folder page will distort a bit) but not to the rest of the desktop.
thanks for all ya help guys!
by the way, i never meant i knew it werent the driver, i meant ive updated it to the latest driver so that should not be the problem. thanks!
ill get back to you if the problem persists :)
No worries fella. I like to call this troubleshooting hell and well misery does love company :)
I checked the laptop spec. It should have a radeon IGP, all the reflows i've done I seem to recall being nvidia chipset. Doesn't rule that out as the cause though......maybe ask what was done on the refurb?
this model is the intel one, has a gma 4500 i believe, and they wouldnt have a clue whats been done, cos the one he sent me had 3gb not 4. rung the guy he apologised prefusely cos hes bought about 20 got an "engineer" to put 4gb in each except this one he missed this one lol. as i say it appears to be working but i have a 90 day no quibble warranty, so if it happens over the next week ill just send it back. other than that, its a bonny laptop, looks really nice, feels well made, shame about these inherant problems i never read about, all the reviews seemed to be dead good.
spec on this is: p8400 processor, 3gb ram (gonna be 4 on tuesday cos he is giving me a 2gb stick of ram free cos it only had 3gb in) erm intel display adapter 14.1" screen i believe its the webcam-less model, has some nightlight (but my mum will never use the cam anyway, its her laptop).
thanks buddy, yeah its been hectic setting it up and all, but finally appears as though we are all good. thanks mate. ste
That's what she wants you to think ;)
:p
she doesnt even know how to use most of the features on her laptop haha, you dirty SOB! lol
but i have noticed a bright spot in the lcd, you notice it from looking at the screen from a side angle and you can clearly see a circle maybe 1cm in size of really white light, im sure its a case of pixel burn or something, is this a major issue that could later lead to further issues? if the lcd could die soon ill send the laptop back, cos i have a 90 day returns policy if its faulty, no quibbles. cheers! ste
Starting to sound like a can of worms this :(
If i recall you paid slightly over £200 for it. Seeing as you can get a new i3 laptop for £300ish with a much longer warranty. I would send it back and buy new
i know theres been niggling pains, but we cant budge at all on the price, we wanted a business laptop because of superior build quality, there designed to last 5 years, and i dont know of any brand new business machines near 350 quid to be honest. we were tight on money as it was :/
turns out it was the visualization turned out to be the problem with the graphics, turned on in the bios, turned it off and fixed it, the lcd screens the only thing that bugs me, but im a perfectionist, my mums not bothered about it, she doesnt notice it.
