Hi
My housemates laptop is on the fritz! ITs an HP Pavilion ZE2000. I think its either a problem with the HDD or the RAM. Ive been tryign to copy her files off for 3 days now with Unstopable Copier, almost every file generates errors!
To be able to test my HDD or RAM theory I want to format and reinstal Windows and also run Memtest. Trouble is the boot sequence is set to HDD first, and the BIOS is password protected so I cant change it!
Does anyone know how I can either reset the BIOS so that the password goes, or find out what the password is?
(If it is the HDD, ill be in the MM looking for a cheap small 2.5" IDE drive, if you have any)
Cheers
Cheers
