i got hold of a HP prodesk 400 g4 mini and its got no wifi. looking inside its got space for a wifi card but no antennas. is it just the case of slapping in a wifi card and then getting some ipx to sma cables and fitting them into the case?
iv got a wifi module lying around that should fit. but i dont see any internal antennas available for this model.
On these it isn't an internal antenna, it's a small rectangular unit that clips to the back - notches in the top left corner of your first picture, the WiFi cables run along the left side in the gap between the motherboard and case.
If you get stuck I can take a photo when I'm back in work on Monday.
you ever had to replace the thermal paste on these small machines? or is the stock application good enough?
