I have used iLO on one or two of them yep, I usually just use the standard version but I have trialed the advanced version and it worked as described.
Non as DCs but we have DL380 which are and they are working fine (1x QC 2.83Ghz, 4Gb RAM and 2x 72Gb SAS 15k hard disks). No reason why a DL360 can't do it.
I do have a DL360 for our Exchange 2007 HUB and CAS roles. 2x 3Ghz QC Xeons, 8GB ram and 4x 72Gb SAS 15k disks. Works a charm!
Esxi runs very well on them as well. Just converted two underutilized citrix servers to esxi, now running 3 virtual servers on each (limited to the 4gb of ram I have unfortunately)
Hmm, never thought of VM but that is a good idea. 2 or 3 DL360s with 2x QC and 32GB RAM and a Fibre HBA for SAN connection could make a nice Hyper-V / ESX setup. Compact rack wise too
Best 1U rack server in it's class, excellent for Web, TS, DC, Citrix and Virtual Front End Servers. As mentioned above it has expansion capability for upto 6 SFF SAS drives making it a nice FAP server also.
Got plenty of DL360's
1 is our domain controller, 1 runs Ex2003 very nicely.
Used to run GSX server on a DL360 before we moved to DL380's and ESX.
They do the job, take a good hammering and still keep going.
May be a bit biased in that we resell HP gear
All looking promising, no bad reviews. Just the decision between the 360 or the 380. As I say will be used as DCs with windows 2008. Network has just over 1000 users with no more than 200 being on concurrently.
DL360s are great, been using them since the G1. I've just installed a 2 node ESX cluster using a pair of G5s with 32GB each and an EMC Clariion AX4 SAN.
You would go for a DL380 if you needed the extra internal drives or expansion slots - ESX servers often have a lot of NICs to support multiple VLANs.
