Just go for it, if you don't like it you can just boot back into webOS. I prefer it as an Android device apart from the battery life is worse under Android than it is under webOS.
I only have the first Alpha build of ICS but the main thing was it killed the battery pretty quickly. I only get maybe 4 hours usages out of it and a couple of days of standby where as on WebOS I get a couple of weeks and many more hours out of 1 charge.
Has the battery drain been improved in more recent builds?
It isn't as good, I will give you that and it has been so long since I used webOS I can't really remember what I could get out it. webOS had potential but my God the web browsing alone put me off. The new ICS 4.04 nightly builds run like a dream (still no camera). As you say it isn't really much of a hassle as I won't use it more than e.g. the length of a football match. There is a TP Android thread here but here is what you need to get Android (video guide is in there).
I use the CM9 alpha 2 and very pleased with it. The lack of camera is a shame, hopefully that will be addressed at some point and then I can fore go taking a netbook with me for skype.
