The HR-01 had no clips originally - but thermalright now do clips for it.
It's the first question on the TR website...
Question : I have a HR-01 and I would like to install a 12cm fan on it. Is there a fan wire clip that can be purchased?
Answer : Fan wire clips are now included in all HR-01 packages. If your package doesn’t include a set, mostly likely you’ve purchased an earlier version. If that’s the case, please contact your local retailer, or write to
[email protected]
as WJA96 said it works better with the duct
