HS seating
13 Sep 2006
running from 8igdave
I have a Q6600 with one core at about 40-45 deg
one at 50 - 50
another at 60-70
and another at 60-70
operating @ 9*400 (3.6)with just over 1.375V
G0 stepping
Y are the cores getting such diff temps. is it becasue I haven't seated the HS right maybe? Im using arctic silver with http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-SB&groupid=701&catid=57&subcat=
I think i might have put much paste on (if it is the HS which is causing this).
am i making a mountain out of a mole hill here? first time at OCing, I have it running at 3.2 nice and stable though.
Are those idle or load temps? And if they're load, which software is applying the load?
Unless you're running Orthos to get those temps, then the heatsink isn't fitted correctly, either being lop-sided or too much paste (Orthos only tests 2 cores and can give funny temps).
Sounds like you havn't done the correct paste application. Horizontal line in relation to the little gold triangle, right across the heatspreader, right?
using prime and yes it is under load.
and looks like the paste is the issue. i did a figure of 8 as i put a small bit on and it didn't seem to cover it when the HS was on.
dam :rolleyes: i would say i noobed but david i keeping a running tally ;)
You needed twice now huh :p
I think i got a problem with my mobo tbh, it blue screens just playing bf2 or even installing the patch. Somethign not right.
blue screen isn't the CPU overheating though is it?
mabey not enough Vcore?
hmmm core temp gives me diff temps to speedfan?
still a 10-3 degre diff between core 0,1 and 2,3 though
blue screen is instability. could be caused by heat.
It's normal to have a difference (my Q6600 had an 11c difference, tho that was quite extreme).
done (not a pro job ill admit) but it seems to have done the trick.
I now have a 5/6 degree diff between cores 0&1 and 2&3. Much better than the 10+ of before.
trying out 9X400 to get 3.6GHz with prime
been going 15mins and hasn't hit 70 unlike before either. Ill need to up Vcore though.
