HTC one battery life issue.
Then you've all got something leaking in the background.
Check location, turn off reporting history etc
In accounts and sync, only have ticked what you actually require to update.
If you're rooted, download "Disable Service" app, and go to the apps that have a blue number next to them and disable.
The main culprit in 4.3 is googles framework, so try clearing cache/data then rebooting. If rooted again, download "System Tuner" app, and then I can tell you some certain aspects of the framework that are safe to disable and will definitely increase battery life.
i have advance task manager on mine ,, light display set low ,, bluetooth and wifi off ,, and disabled the factory apps that u cant uninstall ,,,, lasts 42 hours
i did once get a cheap china longer data cable but took all nite to charge it compared to a short proper htc cable, which takes about 40 mins max
lol google secretly ruining bit-coins on your phone lol
turned off location settings
phone back to normal.
cheers HTC. moronic update and terrible, untested coding...
shoddy company. she will be getting a nexus device next most likely after this.
