Morning everyone, As the title suggests, i'm building my first HTPC and need some advice on what components I should get...
Mobo - Gigabyte GA-F2A88XM-HD3 (AMD A88X)
CPU - AMD A8 7600 X4 (4x3.1GHz)
RAM - 8GB 1866MHz DDR3 CL10 DIMM HyperX Fury Black Series
CPU Fan - Cooler Master Hyper TX3 EVO 3 Heatpipes/1x92mm Fan
SSD - 120GB Mushkin SSD SATA-III, Read 555MB/s, Write 525MB/s - Silent
HDD - 1 TB Seagate (1000 GB) SATA-III HDD 7200 RPM 64MB
What are your opinions on the above? Anything you would change? My main aim is to have a powerful dedicated HTPC thats quiet and future proof (to an extent)
Still trying to figure out
Case Fan
Mobo Ethernet LAN
Wireless Network Card (PCI-e)
TV Tuner Card (PCI-e)
Power Supply Unit
Power Cable
DVD/CD Drive
My budget is around £400
Thanks in advance
Case Fan
Mobo Ethernet LAN
Power Supply Unit
Power Cable
DVD/CD Drive
Thanks in advance
More than enough.
