Hi i need to start a build soon i have been putting it of to see if Trinity would appear but enough is enough so i am looking for a mATX board and cpu for a HTPC build.
So it will be used with a samsung SSD for the os and a 250Gb hard drive for recorded files, all media will be off a WHS and will need to play Hd rips without getting bogged down, it will also have a sat tv card.
I have everything from a previous build so only need the cpu\motherboard.
So the main thing is that i don't want to feel like the system is struggling when i am possibly recording 2 sat tv channels and maybe downloading and trying to play a Hd film at the same time.
So what would you recommend ?
Thanks
Robert
Thanks
Robert
