- 3 Aug 2012
Hi all,
Just want to build an HTPC for myself.
Requirements:
* Room for 2 x 3.5 Disks (Have some Samsung Green 2TB)
* SSD for OS
* HD Audio over HDMI
* Preferably no need for GPU card, possible to use mobo/CPU?
* Case height limited to 14cm (can always put it on its side)
* Blu-Ray
I will be using it to play MKV, ISO, BDISO via existing AV equipment. This will be replacing a Med8tor (which I will re-house upstairs).
Could anyone give me a spec please?
I'd like to keep as inexpensive as possible.
Thanks
Requirements:
* SSD for OS
* Blu-Ray
Thanks
