Looking for an HTPC Case that would be able to fit the following spec,
Core 2 Duo e6300
2gb Corsair Value Select Ram
Asus P5LD2-SE Mobo
1x250GB+1x80GB HDD's(one has Vista one has XPMCE)
Hiper Type R 580W PSU
2xDVD RW Drives, Could easily take this to 1 quite happily
8800GTS 320MB(most crucial is to make sure this fits)
Zalman 9500LED Cooler(obviously possible clearance issues)
So what can you guys recommend? The silverstones seem like pretty decent value and have just about everything I would want. Its just looking at the reviews I cant gather any info on what kind of GPU's and CPU coolers they can support.
I would prefer not to change my CPU cooler in the hope I can just transfer the Mobo as assembled from one Case to the HTCP one!
Any help would be super!
Core 2 Duo e6300
Asus P5LD2-SE Mobo
