That is the basket^
Basically I am swapping some stuff around, putting some new stuff in my main rig and taking the old stuff and putting it into a htpc.
Main rig build:
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
His 1gb 6870
1.5tb secondary storage
500gb Os storage
700w OCZ Modular
Cooler master scout
HTPC BUILD:
Intel core 2 quad q8300 (overkill but free)
Asus p5n73-am
4 GB ddr 2
Samsung SpinPoint F4 EcoGreen 2TB
LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive - Black (Retail)
Win TV nova HD S2 ( I wish overclockers stocked this)
Antec 300.
The 700w power supply is the same price as the 600w, also have gone for a modular power supply because it is just so much easier to build with and I like OCZ, Antec 300 because I need it to be quiet and it has tricool and it is cheap and cheerful. Looks do not matter because it will be behind the TV.
The 950 because 1366 is going to be future proof for quite a while, and it packs a good punch.
That motherboard because it has good reviews, Sata 3 and it is 1336 of course.
Also going to be using a few denon speakers+ amps for the surround sound and yes the motherboard that I will be using supports Surround Sound.
Please tell me what you think and there is anything else better instead.
