HTPC Need some specifics
19 Dec 2010
Swansea, Wales
Hi all,
I am trying to put together a basket for my g/fs father. He wants to setup a moderatly powerful HTPC with the capability of 3D and moderate gaming from time to time. He wants 2 HMDI outputs 1 for the TV and 1 for his PC. The 3D will be primarily for films rather than gaming so will he need 3D vision?
Space isnt an issue but he needs it to be in a horrizontal HTPC case, I was thinking something big like the Silverstone LC13B or LC17B?
I think the budget is around £400. He has 2 external harddrive NAS and their all connecting using GIGABIT.
If you could suggest a decent motherboard for the large case and a moderate graphics card that is capable of 3D that would be great. One decent internal drive for the OS and games is needed, everything else is on external so around 4-500gb should be fine.
Thanks all :)
Hi and welcome to forums
Spending eighty odd quid on a case within a 400 budget doesnt leave you much for the rest, also wanting 3d and gaming within that budget is going to be a stretch too tbh, theres a coupla different HTPC spec options in the guide in my sig if you want a look
This build has everything you want but is over budget, youre going to have to compromise on either budget or desired spec (though you could drop cpu back to a dual core athlon but youll still be over - just less so)
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card £110.99
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £75.19
Silverstone Sugo SG01B-F Evolution Aluminium Micro-ATX Case - Black £69.99
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £69.98
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £46.99
OCZ StealthXStream 2 500W Power Supply £41.98
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £31.98
LiteOn IHAS124 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA £11.74
Sub Total : £390.51
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £70.40
Total : £472.66
Thanks for that, due to working away I havent managed to get back to the thread!
In the end he didnt care much about the budget and I basically built him a gaming PC in a HTPC case hehe, he's very happy with it now. i5 760, 4gb xms3 ram, and he ordered a 6750 but they sent him a 6950! safe to say he was happy with that! Ordered it from an american site as he lives there, probably NewEgg :)
Thanks for the info and i'll be back with some questions on my own PC soon ^^
