Hi Folks,
I have a HTPC with an onboard ATI 3200 gfx chip. It's connected to my 32" 720p LCD via HDMI. The TVs native resolution is 1366x768.
In the ATI CCC I can't select this resolution, choosing 720p from the TV menu in CCC doesn't seem to work propery so at the moment it is set to 1280x768 but it doesn't really fill the screen.
What are the best settings to use to get the best picture?
Can you explain what overscan does and how it affects the picture quality.
Also, does the Hz setting affect the picture quality, it is set at 30hz at the moment but I think it could go higher.
Thanks
Matt
Thanks
Matt
