Thanks, is your freedom with the headrest? Is it needed on recline?I don’t rate steel case - my work uses them and they’re ALWAYS breaking. And they’re a pig to deal with
Personally use humanscale at home, never had issues
Anecdotal at best but just personal experience
You've highlighted all my concerns with the Freedom without the headrest, but the freedom chair has lots of very positive online reviews (which mainly have the headrest) but nowt for the Please.A positive or negative I suppose.
as I mentioned previously, they break a lot. It’s important to set your weight properly on the chair so that the recline mechanism works properly, but they are typically quite fiddley.
That's interesting I've not had any issues with mine there are only two adjustments for recline... travel and tension not hard to change. Are these Please v2 chairs and what tends to break on them?
The only thing I find a touch annoying is you can catch the seat cushion forward/back adjustment quiet easily with you calf muscle, you just have to watch it if you tend to fold your legs a lot either under the seat or on top of the cushion.
If memory serves correct it tends to be the tilt mechanism and the adjustment knob for the degree of tilt
However I’ve seen chairs with broken arms, especially the padding on the arm rest - I would say about one third of the chairs in the office have broken/split padding
Maybe we are talking about different seats because the Steelcase Please I have the armrests aren't padded, and the recline controls are pretty straight forward. The seat and back cushions will wear out eventually like 10-15yrs but you can refurbish (or replace) them because they are detachable which is really handy in fact that is why you see a lot of refurbished chairs for sale.
They are exchanging. They are sending out a Freedom in its place. I like the high back on the Please, maybe I'm picky, but it's not in great shape and wouldn't want another in a similar state.
