- 7 Sep 2010
This follows on from my previous PSU thread:
http://forums.overclockers.co.uk/showthread.php?t=18274381
Basically, I was talked out of buying a Coolermaster Silent Pro Gold, and having read a few more reviews etc I think I probably had a close escape - it's not a bad unit (for the price, anyway) but there are much better ones few a few quid more. Having nearly taken stulid's advice, I'm looking at the 650W TX-V2, a very solid PSU.
BUT... I also like the look of the HX650, although it is £20ish more. This is definitely over-budget for me, but I am trying to justify this as :
1) It is modular
2) It is 150mm long (TX is 160mm), which does help with my weird case
3) 7 year warranty (vs 5 for TX)
Is the HX just a TX with a modular design? I'm guessing no, as the case size and warranty are different, but they are both SeaSonic 80+ Bronze designs. Or is the HX a significantly better PSU, as well as being modular (and shorter)?
Any opinions/suggestions appreciated, but please DON'T suggest a Corsair AX as my budget is overstretched already!
1) It is modular
