Hybrid drives?
I put a 1tb in my PS4 but if you have a desktop my personal opinion (providing you have the space) is you would be better off going SSD for OS and mechanical for storage.
What are your opinions on the Hybrid SSHD drives please?
Very very slightly better than a normal hard drive. Not even close to a performance of a proper SSD. If the price is neg vs a normal drive then go for it.
I have a 500Gb Seagate Momentus XT kicking around somewhere and it was just about as fast as a normal WD Black Scorpio drive in a laptop
Solid-State Hard Drives attempt to combine the best of both worlds between SSDs and HDDs. SSDs offer huge performance increases, but can be extremely expensive. Traditional HDDs have much larger storage capacities at a friendlier price point, but aren’t as fast. So SSHDs utilize an SSD cache, usually around 8GB, on which the drive places most frequently used files, and then utilizes the larger spinning-disk storage capacity for the rest of your data. One of the reasons that some people don’t find them effective enough is they think the SSD cache is too small. Hopefully with the progress of time, demand, and technological advances, in the future these SSD cache portions will be larger without becoming excessively pricey.
SSHDs are something that you're going to see a spectrum of anecdotal experience on, some people have said they feel like there's negligible benefit to them, others feel like they're fantastic at increasing performance.
The general consensus, from reading through others' experiences on the matter, is that the biggest benefit to them is if you're really into open-world type gaming, there can be a considerable decrease in load-times, particularly when moving into/loading new areas of open-world maps. They can also decrease loading times for important things like your OS. Some people prefer this, while others you'll find prefer using a traditional HDD and an SSD.
Ultimately, it's going to come down to where on the price-vs-performance slider your priorities land.
I think hybrid drives are a very good idea and in theory you have the best of both worlds between capacity, speed and cost. For example typically Windows only uses around 20% of it's files to boot, it's this 20% that is moved to solid state part. They are also perfect for gaming drives where some games won't be played for a while.
HDD's will be around for years yet, however any form of mechanical storage is eventually doomed.
In the future there will be SSD drives with different speed flash memory. You will have say a 2GB SSD, and say 80% will be cheaper slower flash memory, then the other 20% will be more expensive flash memory. It will work similar to hybrid SSD's now, but the cheaper slower flash memory will replace the HDD part. This is how they will get around problem of having SSD's that solve capacity, speed and cost.
Slightly old thread but this information could be useful to people - my laptop has an SSD cache (8GB) system and I've tested it with mechanical, mechanical + SSD cache (basically hybrid) and a proper SSD:
Boot times 40-45 seconds with just HDD, ~19 seconds with hybrid, ~11 seconds proper SSD.
Application and game load times were around 20-30% faster with the hybrid setup but could be 150-300% faster with the SSD.
For working with media files i.e. encoding, etc. I saw zero difference between HDD and the hybrid setup.
