Hi everyone,
After some advice as I am well out of the loop on anything to do with bikes these days...
I am after some Hydraulic brakes for my bike, looked around a bit online but don't know what I want/need or where to get it from.
My bike is a Specialized Stumpjumper HT, I believe it is a 2006/07 model. I have had it for a very long time, but it's not in too bad a condition (apart from the brakes).
The brakes are shot, I've already removed the front brake (used the cable to fix my son's bike).
I want to upgrade to some Hydraulic disk brakes.
For ease, I'd like a complete kit to fit, if that's an option. If not, happy to buy the parts individually. something that's low maintenance? Not sure how much maintenance is required, They won't be getting used loads or abused too much.
Thinking £100-150 if that's possible to get something half decent? Edit: maybe £150 is overkill for what I need!?
Don't know anything about sizing, I assume it is a universal size.
Please help!
The tire and front wheel needs swapping as the mount for the disk is currently on the other side.
Please help!
