- 8 Jan 2007
Hi,
I have the Coolermaster Hyper X 212 & It's cooling my 6600k i5 really well.
However, the coolermaster fan has a bit of an annoying noise to it (when under load). I've noticed this in all Coolermaster fans I've owned to be honest.
I wanted to replace the fan with something a bit more sophisticated/upmarket.
My preference was this:
https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-054-cs.html
Just a few questions:
1. Will this fit?
2. This is designed for CPU use - 4pin yes?
3. Does anyone have experience with these fans? are they quiet?
4. Will the cooling performance be as good? (I'm sitting at about 29c idle & 40c load with the fan in silent mode in the bios, currently).
Thanks
Tom
1. Will this fit?
Thanks
Tom
