** HYPERX FURY PRO MOUSE PADS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
I have been putting this off for a while now but Kingston have come in and put one of their new Fury pads on my desk and told me to use it.
The main reason I have been putting it off is due to the competition.
As many of you are aware, the SteelSeries QCK is easily the most professionally used surface range in esports. Even by players sponsored heavily by other brands!
The HyperX fury mouse pads are basically what Kingston/HyperX think a great mouse mat should be. They are honestly, quite similar to the QCK range which is no bad thing. The advantages are that they offer good pricing and sizes not on offer by other brands.
The Small and Medium are very basic in fairness. Perhaps good for high sensitivity players or those with limited space. Quality is nice and the design is fairly clean.
The Large and XL are where this range will really hit the market hard.
Large is similar in dimensions to the best selling QCK Heavy and it tracks pretty much the same.
The XL is the same thickness but with a full desk approach, something not many competitors have done, or at least done well. Generally the full desk mats are either too thin or the surface doesn't track precisely enough.
Put simply, I have used the Large Fury mat for about 20 minutes and can honestly say it is one of the best mats we sell. It is also cheaper than many of its equivalents.
The items are on for pre order here and will be in stock this week.
HyperX FURY Pro Gaming Mouse Pad - Small @ £7.49 inc VAT
HyperX™ FURY Pro Gaming Mouse Pad has a high-quality fabric pad that’s soft yet resistant and heat-treated for a controlled glide to put you in the lead, whether you’re a gamer in a death match or a professional racing the clock. FURY’s natural rubber and cross-weave underside provide padding for your wrist to keep you comfortable and supported and help the pad grip the surface firmly for more stability.
Features
Superior quality fabric pad
Natural rubber for comfort and stability
Four different sizes
Suitable for any play style and space requirement
Portable and durable; easy to roll up and resistant to wear and tear
Two-year warranty
Width x Length:
S: 240mm x 290mm
Only £7.49 inc VAT.
ORDER NOW
HyperX FURY Pro Gaming Mouse Pad - Medium @ £9.95 inc VAT
Features
- Superior quality fabric pad
- Natural rubber for comfort and stability
- Four different sizes
- Suitable for any play style and space requirement
- Portable and durable; easy to roll up and resistant to wear and tear
- Two-year warranty
Width x Length: M: 300mm x 360mm
Only £9.95 inc VAT.
ORDER NOW
HyperX FURY Pro Gaming Mouse Pad - Large @ £14.59 inc VAT
Features
- Two-year warranty
Width x Length:
L: 420mm x 500mm
Only £14.59 inc VAT.
ORDER NOW
HyperX FURY Pro Gaming Mouse Pad - Extra Large @ £20.26 inc VAT
Features
- Two-year warranty
Width x Length:
XL: 420mm x 900mm
Only £20.26 inc VAT.
ORDER NOW
Is the "feel" of the fabric similar/the same to the OCUK ones? had the OCUK ones for years now since you started selling them, love the feel, they are nice and smooth.
My current one, is getting alittle tattered with years of use.
Need to replace it will the same one or similar.
This would go nicely with my headset :D
they are very similar. the finish is sleek and the movement and glide of the mouse is spot on.
if you are an ocuk mat user then the XL hyper X fury is a great alternative as it is much thicker. this means that it tracks well and evens out any deformities in your desk surface
