Ok...
If I'm filtering I tend to use the clutch a fair bit, as I like to blip the throttle to let car drivers know I'm there.
I like to carry it out while wearing nothing but my helmet and a pair of old hole filled y fronts for protection.
Edit: and a POLITE high vis.
Really cant see its any safer
when I filter I stop every 3 cars to do a burnout. Much safer because my rubber is kept at right temp in case I need to brake.
you might get rear ended between two cars by another biker whos pre occupied adjusting his hole filled y fronts while doing crotchless shiftingthough
lube helps in those situations![]()
I don't really see the need to shift gear without the clutch.
I know you can but why, if those split seconds were really that important I would have set off earlier in the first place.
Why rev match on down shifts?
Why lean off the seat?
Why tuck?
Why have a nice exhaust?
Why have more than 40hp?
Why accelerate hard?
Why not?
I'll say the same thing as I do in every one of these threads...
Quickshifter and clutchless downshifts![]()
